Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail. With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
  • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
  • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
  • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
Insertar traducción aquí
