Saltar al contenido principal
Inglés
Español
Paso 7
You can now lift the speedometer assembly out, carefully. Note that there are wires that cross behind the gauge face; you will need to clear these wires to remove the gauge. You can now lift the speedometer assembly out, carefully. Note that there are wires that cross behind the gauge face; you will need to clear these wires to remove the gauge.
  • You can now lift the speedometer assembly out, carefully. Note that there are wires that cross behind the gauge face; you will need to clear these wires to remove the gauge.
Ahora puede levantar el conjunto del velocímetro con cuidado. Tenga en cuenta que hay cables que se cruzan detrás de la cara del medidor; deberá despejar estos cables para quitar el medidor.
