Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 2
Locate the volume switch on the right side of the motherboard next to the circle pad joystick. Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
  • Locate the volume switch on the right side of the motherboard next to the circle pad joystick.
  • Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
Insertar traducción aquí
