Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Begin by disconnecting your battery, pulling off the negative (-) ground cable.
  • Begin by disconnecting your battery, pulling off the negative (-) ground cable.
  • This is required for this process! There is a constant 12v supply of power to your car's clock, even when the key is off. If you attempt to pull the cluster out with the battery connected you will burn up part of your cluster's circuit board, or worse yet hurt yourself.
Insertar traducción aquí
