Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out. The battery wire harness will slide out as the battery is pried up. The battery wire harness will slide out as the battery is pried up.
  • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
  • The battery wire harness will slide out as the battery is pried up.
Insertar traducción aquí
