Saltar al contenido principal
Inglés
Español
Traduciendo paso 3
Paso 3
Do not try to remove the keyboard immediately. It is still connected to the motherboard by a ribbon cable that can be easily damaged. Once the keyboard is unscrewed, the ribbon cable below will also need to be disconnected. Lift up the "flap" securing the ribbon cable to their slot on logic board and slowly pull the cables away from their connections.
  • Do not try to remove the keyboard immediately. It is still connected to the motherboard by a ribbon cable that can be easily damaged.
  • Once the keyboard is unscrewed, the ribbon cable below will also need to be disconnected.
  • Lift up the "flap" securing the ribbon cable to their slot on logic board and slowly pull the cables away from their connections.
  • Lift the keyboard assembly up and away from the plastic chassis.
Insertar traducción aquí
