Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 3
Loosen the two Phillips #00 screws that are securing the hard drive compartment. The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely. Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
  • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
  • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
Insertar traducción aquí
