Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 7
Using a plastic opening tool pop off the circle pad joystick. Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
  • Using a plastic opening tool pop off the circle pad joystick.
  • Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
  • There is a loose washer located in between the circle pad joystick and the circle pad. Use caution and do not lose this piece.
Insertar traducción aquí
