Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 9
The motherboard will still be attached at the top right hand corner so do not completely detach it at this point. Carefully lift the board straight up just enough to clear the two plastic mounts located near the top corners of the cartridge slot.
  • The motherboard will still be attached at the top right hand corner so do not completely detach it at this point.
  • Carefully lift the board straight up just enough to clear the two plastic mounts located near the top corners of the cartridge slot.
  • Gently flip the motherboard over the top side.
Insertar traducción aquí
