Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 2
Locate the volume switch on the right side of the motherboard next to the circle pad joystick. Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
  • Locate the volume switch on the right side of the motherboard next to the circle pad joystick.
  • Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
Insertar traducción aquí
