Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 16
Use the flat end of a spudger to disconnect the headphone jack connector from the logic board. Pry up only on the connector—not on the socket itself. Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
  • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
  • Pry up only on the connector—not on the socket itself.
  • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
  • Fold the headphone jack cable out of the way.
Usa el extremo plano de un spudger para desconectar el conector jack de auriculares de la placa lógica.
Haz palanca solo en el conector, no en el zócalo.
Las nuevas unidades de iPad tienen un bucle de cinta que conecta este conector a su zócalo en la placa lógica. Esta cinta debe cortarse para desconectar la toma de auriculares.
Dobla el cable de la toma de auriculares fuera del camino.
