Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 26 guías que incluyen este paso.
Inglés
Español
Paso 3
Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets. To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board. To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
  • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
Usa el extremo plano de un spudger o una uña para sacar con cuidado los dos conectores del cable del digitalizador directamente desde sus enchufes.
Para evitar dañar tu iPad, haz palanca solo en los conectores, no en el zócalo de la placa lógica.
