Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
When reassembling your device, attach the gasket to the heat sink as shown. The tail of the gasket should fit into the notch in the heat sink, it should not end up underneath the heat sink tab that will rest on the logic board.
  • When reassembling your device, attach the gasket to the heat sink as shown.
  • The tail of the gasket should fit into the notch in the heat sink, it should not end up underneath the heat sink tab that will rest on the logic board.
  • Be sure the small post molded into the rubber gasket mates with the hole cut into the upper right corner of the logic board.
Insertar traducción aquí
