Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 2
Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure. Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
Remove the hard drive bracket screw
  • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
Remueve el tornillo Phillips de 6.5 mm que sujeta el soporte del disco duro al recinto.
[title] Remove the hard drive bracket screw
-[* red] Remove the 6.5 mm Phillips screw securing the hard drive bracket to the enclosure.
+[* red] Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
