Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Insert the head of a flathead screwdriver into the seam between the front cover and the phone. Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
  • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
  • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
  • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
Insertar traducción aquí
