Saltar al contenido principal
Inglés
Español
Paso 3
Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips Continue to slide the tool along the slot until you feel the plastic locks disengage Once all locks have released, the bottom frame can simply be removed.
  • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
  • Continue to slide the tool along the slot until you feel the plastic locks disengage
  • Once all locks have released, the bottom frame can simply be removed.
Insertar traducción aquí
