Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 3
Remove the four T8 (lower right screw is 3.8 mm, the other 3 are 11 mm) Torx screws from the corners of the hard drive bracket.
  • Remove the four T8 (lower right screw is 3.8 mm, the other 3 are 11 mm) Torx screws from the corners of the hard drive bracket.
  • Make sure you're removing the screws from the hard drive bracket, not the hard drive itself.
Insertar traducción aquí
