Saltar al contenido principal
Inglés
Español
Traduciendo paso 3
Paso 3
After removing the panel, you will see two memory modules. Locate the four spring clips that are holding the memory modules in place. Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
  • After removing the panel, you will see two memory modules.
  • Locate the four spring clips that are holding the memory modules in place.
  • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
  • Gently raise the memory module and lift it out of its socket.
Insertar traducción aquí
