Saltar al contenido principal
Inglés
Español
Paso 9
With the display thusly removed, we just have to convince it to part with its home button. We let our plastic opening tool do the talking. Say goodbye to the sticky adhesive tape holding the screen down. Reinstalling your display will most likely require a fresh set of adhesive. This little display assembly cable has a lot of bits to ferry. It's helped out by a Synaptics S5100A touchscreen controller.
  • With the display thusly removed, we just have to convince it to part with its home button. We let our plastic opening tool do the talking.
  • Say goodbye to the sticky adhesive tape holding the screen down. Reinstalling your display will most likely require a fresh set of adhesive.
  • This little display assembly cable has a lot of bits to ferry. It's helped out by a Synaptics S5100A touchscreen controller.
  • This is a fairly radical change in design for the S-series. We're used to seeing internal components riding on the back of a large display assembly. The S5 turns this on its head and sandwiches the components between the display and the battery, in their own difficult-to-access compartment.
Con la pantalla extraída, tenemos que convencerla de despedir a su botón de inicio. Dejamos que nuestra herramienta de apertura hable por nosotros.
Dile adiós a la cinta pegajosa adhesiva que sujeta la pantalla. Para volver a instalar tu pantalla seguramente necesitarás un nuevo conjunto de adhesivo.
El pequeño cable de ensamblaje de pantalla tiene un montón de pedacitos para transbordar. Lo ayuda el controlador de pantalla táctil Synaptics S5100A.
Este es un cambio bastante radical en el diseño para la serie S. Estamos acostumbrados a ver componentes internos en la parte trasera de un ensamblaje grande de pantalla. El S5 los tiene en la parte superior y atrapa a los componentes entre la pantalla y la batería, en su propio compartimento difícil de acceder.
