Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Remove screw covers (4 in total) using the spudger. Note: Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone. Note: Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
  • Remove screw covers (4 in total) using the spudger.
  • Note: Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
Insertar traducción aquí
