Saltar al contenido principal
Inglés
Español
Traduciendo paso 13
Paso 13
Amazon Fire TV Repairability Score: 6 out of 10 (10 is easiest to repair) Simple construction—upper case, lower case, heat sink, motherboard. Once it's apart, there's not much to keep track of.
  • Amazon Fire TV Repairability Score: 6 out of 10 (10 is easiest to repair)
  • Simple construction—upper case, lower case, heat sink, motherboard. Once it's apart, there's not much to keep track of.
  • The power supply is separate; should it ever need replacement, there'll be no disassembly required.
  • Standard Phillips screws populate the internals, making this box a worry-free affair once you're inside...
  • ...provided you never need to remove the heat sink, which is secured with copious amounts of extremely sticky glue.
  • The outer case is a very tight fit. Plastic clips are used rather than glue, but they're so stubborn you'd be forgiven for thinking otherwise.
  • A single board hosts all the vitals—clean and simple, but when it comes to repair, it's all or nothing.
Insertar traducción aquí
