Saltar al contenido principal
Inglés
Español
Paso 10
First to remove the mic cable. All connections in this headset are soldered. If possible, slide the heat shrink off the soldered connections to separate them with a soldering iron these are the cord clips holding which  prevent the cables from being pulled out of the dome. The connections where the heat shrink tubing can not be removed, are cut with a pair of pliers.
  • First to remove the mic cable. All connections in this headset are soldered. If possible, slide the heat shrink off the soldered connections to separate them with a soldering iron
  • these are the cord clips holding which prevent the cables from being pulled out of the dome.
  • The connections where the heat shrink tubing can not be removed, are cut with a pair of pliers.
  • With the mic cable connected, pull the cable inside the dome to gain easy access to the cord clip
Insertar traducción aquí
