Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 14 guías que incluyan este paso.
Inglés
Español
Paso 9
Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro. You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
  • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
  • You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
  • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
  • Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board, and then remove the logic board and MagSafe board together.
Levantando desde el lado más cercano a la batería, gira la placa lógica hacia la parte superior de la MacBook Pro.
Puede ser que debas deslizar la placa lógica unos pocos milímetros hacia la izquierda para que haya espacio libre para los puertos a lo largo del borde derecho de la placa.
Usando el extremo plano de un spudger, empuja con cuidado el conector MagSafe 2 fuera de su zócalo en la parte inferior de la placa lógica.
[* black] Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
[* icon_note] You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
[* black] Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
[* icon_note] Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply [https://d3nevzfk7ii3be.cloudfront.net/igi/GOcrO3AMpJXvKgv2|remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board|new_window=true], and then remove the logic board and MagSafe board together.
