Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 40 guías que incluyan este paso.
Inglés
Español
Paso 3
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
  • Use caution when freeing the cable, as it is strongly adhered to the logic board.
Usa la punta de un spudger para levantar la aleta de retención del zócalo ZIF del cable plano del ventilador derecho.
Asegúrate de hacer palanca en la aleta de retención con bisagras, no al zócalo en sí.
Comenzando en la parte superior del cable, desliza una herramienta de apertura de plástico debajo del cable del ventilador derecho para liberarlo de la placa lógica.
Ten cuidado al liberar el cable, ya que está fuertemente adherido a la placa lógica.
[* black] Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF[guide|25629|ZIF|stepid=64969|new_window=true] socket.
[* icon_caution] Be sure you are prying up on the hinged retaining flap, '''not''' the socket itself.
[* black] Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
[* icon_caution] Use caution when freeing the cable, as it is strongly adhered to the logic board.
