Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Traduciendo paso 9
Paso 9
Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
[* black] Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro. |
[* icon_note] You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board. |
[* black] Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board. |
[* icon_note] Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply [https://d3nevzfk7ii3be.cloudfront.net/igi/GOcrO3AMpJXvKgv2|remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board|new_window=true], and then remove the logic board and MagSafe board together. |
