Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside) Make sure your Micro SD card is removed from the device Micro SD card slot. Disconnect the microphone using your fingers, be careful not to do too much pressure.
  • With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
  • Make sure your Micro SD card is removed from the device Micro SD card slot.
  • Disconnect the microphone using your fingers, be careful not to do too much pressure.
Insertar traducción aquí
