Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB.  It has 1MB soldered to the logic board as well. Start with this SIMM.  Push these 2 metal tabs outward, then push the ram forward.  It can then be lifted out.  You have to remove the SIMMs in order, starting with the one you just removed.  You can then work your way through all of them. Start with this SIMM.  Push these 2 metal tabs outward, then push the ram forward.  It can then be lifted out.  You have to remove the SIMMs in order, starting with the one you just removed.  You can then work your way through all of them.
  • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
  • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
El Macintosh IIsi usa 4 RAM SIMMs de 30 pines, instaladas en pares de dos para una capacidad máxima de 65 MB (4x16MB +1MB). Tiene además 1MB de RAM soldada a la placa lógica.
Comienza con este SIMM. Empuja estas 2 pestañas de metal hacia afuera, luego empuja la Ram hacia adelante. Entonces se puede levantar. Debes quitar los SIMM en orden, comenzando por el que acabas de quitar. A continuación, puedes continuar con los siguientes.
