Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
Using your hands, grasp the wire that is still connected to the power supply. Carefully lift the power supply off the threaded stud to which it was coupled. At this point you will have removed the following parts from the kettle:
  • Using your hands, grasp the wire that is still connected to the power supply. Carefully lift the power supply off the threaded stud to which it was coupled.
  • At this point you will have removed the following parts from the kettle:
  • Five (5) screws.
  • The kettle base.
  • One (1) 7/32'' hex nut.
  • One (1) 7/32" split-ring lock washer.
  • One (1) power supply unit.
Insertar traducción aquí
