Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 6
Using a 7/32" nut driver, remove the hex nut that secures the power supply to the base of the kettle. Using a pair of tweezers, remove the split-ring lock washer located under the nut. (It may be hard to see in low light.)
  • Using a 7/32" nut driver, remove the hex nut that secures the power supply to the base of the kettle.
  • Using a pair of tweezers, remove the split-ring lock washer located under the nut. (It may be hard to see in low light.)
Insertar traducción aquí
