Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
Take note of how the wires connect to the components to aid reassembly. Remove the connectors (spaded lugs) from the circuit components as shown in the second image. DO NOT pull on the wires, as you might pull them out of the connectors.
  • Take note of how the wires connect to the components to aid reassembly.
  • Remove the connectors (spaded lugs) from the circuit components as shown in the second image.
  • DO NOT pull on the wires, as you might pull them out of the connectors.
  • You should be able to remove each connector easily by hand. Pinch the lug between your fingers and pull in the direction of the attached wire.
  • If necessary, use needle-nose pliers to grasp the lug shank firmly. Gently pull the lug in the direction of the attached wire.
  • Gently bend the disconnected wires back and out of the work area.
Insertar traducción aquí
