Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Using a Phillips #2 screwdriver, remove the front two 8mm screws attaching the chassis to the base. Flip the toaster around and proceed to remove the two remaining 8mm screws. The toaster chassis should now only be connected to the base via wiring.
  • Using a Phillips #2 screwdriver, remove the front two 8mm screws attaching the chassis to the base.
  • Flip the toaster around and proceed to remove the two remaining 8mm screws.
  • The toaster chassis should now only be connected to the base via wiring.
Insertar traducción aquí
