Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device. Lift the bottom body slightly away from the core at a 45 degree angle. Lift the bottom body slightly away from the core at a 45 degree angle.
  • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
  • Lift the bottom body slightly away from the core at a 45 degree angle.
Insertar traducción aquí
