Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free.
  • Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly.
  • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
Insertar traducción aquí
