Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
This fuse, while not broken or burnt, was removed for inspection. The element was bent, and the end piece was loose and crooked. It was replaced on principle. Before replacing any fuses, check the housing connection points for corrosion. If you find any you can clean it up with a brass bristle brush
  • This fuse, while not broken or burnt, was removed for inspection. The element was bent, and the end piece was loose and crooked. It was replaced on principle.
  • Before replacing any fuses, check the housing connection points for corrosion. If you find any you can clean it up with a brass bristle brush
Insertar traducción aquí
