Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
A plastic sheet is in between the radio motherboard (the upper brown board) and the audio port daughterboard (the lower green board) coming from the right speaker housing. Be careful when removing the back panel as to not damage the boards. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free.
  • A plastic sheet is in between the radio motherboard (the upper brown board) and the audio port daughterboard (the lower green board) coming from the right speaker housing. Be careful when removing the back panel as to not damage the boards.
  • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
Insertar traducción aquí
