Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Paso 4
With one spudger, work your way along the right edge of the iPad. The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides.  The right side has plastic tabs which slide into recesses in the backplate.
  • With one spudger, work your way along the right edge of the iPad.
  • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
  • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
  • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
Insertar traducción aquí
