Saltar al contenido principal
Inglés
Español
Paso 7
To separate the ribbon cable side of the display bracket, begin by heating near the lower left corner of the panel (as viewed from the front of the iPad). Carefully separate the lower edge of the ribbon cable side of the frame until you reach another area where rubber connects the frame to the glass panel. Repeat the process outlined in previous steps to cut through the rubber "dots" connecting the two pieces.
  • To separate the ribbon cable side of the display bracket, begin by heating near the lower left corner of the panel (as viewed from the front of the iPad).
  • Carefully separate the lower edge of the ribbon cable side of the frame until you reach another area where rubber connects the frame to the glass panel.
  • Repeat the process outlined in previous steps to cut through the rubber "dots" connecting the two pieces.
  • Be careful when separating this side, as there is fragile ribbon running beneath the frame.
Insertar traducción aquí
