Saltar al contenido principal
Inglés
Holandés
Paso 8
The battery is held to the rear panel by an excessive amount of adhesive. Proceed with patience and caution. Use the flat end of a spudger to gently pry the battery up from the the lower case.
  • The battery is held to the rear panel by an excessive amount of adhesive. Proceed with patience and caution.
  • Use the flat end of a spudger to gently pry the battery up from the the lower case.
  • Gently continue to enlarge the gap by wiggling the spudger and running it along the right side of the battery.
  • Continue to pry until the right side of the battery is free from the rear panel.
Insertar traducción aquí
