Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 7
The battery is quite obvious to pick out of this picture of the rear case (sans display assembly). The 3.75V, 24.8 watt-hour (6.5 Amp hour [!]) battery provides the juice for an advertised 10 hours of use. In contrast, the iPhone 3GS has a  4.51 watt-hour battery and the MacBook Air has a 40 watt-hour battery. The battery seems to integrate two separate 3.75V lithium polymer cells wired in parallel for such ample battery life.
  • The battery is quite obvious to pick out of this picture of the rear case (sans display assembly).
  • The 3.75V, 24.8 watt-hour (6.5 Amp hour [!]) battery provides the juice for an advertised 10 hours of use. In contrast, the iPhone 3GS has a 4.51 watt-hour battery and the MacBook Air has a 40 watt-hour battery.
  • The battery seems to integrate two separate 3.75V lithium polymer cells wired in parallel for such ample battery life.
  • The USB power supply had to be enhanced specifically for the iPad. It's a 10W unit manufactured by Foxlink Technology, Ltd., part #A1357 W010A051.
Insertar traducción aquí
