Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Open the cord winding flaps. Heat the power brick's plastic casing with a hair dryer, and/or run a razor blade along the seam between the two halves of the casing, in order to weaken the adhesive. This will make it easier to pry the case open. Insert your pliers and pry slowly. (Make sure they stay seated in the inside corners, or you may injure yourself or gouge the case.)
  • Open the cord winding flaps.
  • Heat the power brick's plastic casing with a hair dryer, and/or run a razor blade along the seam between the two halves of the casing, in order to weaken the adhesive. This will make it easier to pry the case open.
  • Insert your pliers and pry slowly. (Make sure they stay seated in the inside corners, or you may injure yourself or gouge the case.)
  • The cord winding flap will fall out.
  • Do the same on the other side.
  • Work slowly!
Abre las aletas de enrollamiento del cable.
Calienta la carcasa de plástico del adaptador de corriente con un secador de pelo, y/o pasa una cuchilla de afeitar a lo largo de la costura entre las dos mitades de la carcasa, para debilitar el adhesivo. Esto facilitará la apertura de la caja.
Inserta tus alicates y haz palanca lentamente. (Asegúrate de que permanezcan insertados en las esquinas interiores, o puedes lesionarte o dañar la carcasa).
La aleta de enrollamiento del cable se caerá.
Haz lo mismo en el otro lado.
¡Trabaja despacio!
