Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
If your charger is never opened before, it would be difficult to pry it open. Try bench-vise tools to add power your needle nose plier
  • If your charger is never opened before, it would be difficult to pry it open. Try bench-vise tools to add power your needle nose plier
  • Handle of your needle-nose plier is laid upon the closed bench vise, insert into the casing, then roll the vise slowly.
  • The casing would be cracked and you can continue to next step
Si tu cargador nunca se ha abierto antes, será difícil abrirlo. Prueba los tornos de mesa para agregar potencia a tu alicate de punta fina.
El mango de tu alicate de punta fina se coloca sobre el torno de mesa cerrado, insértalo en la carcasa y luego gira el torno lentamente.
La carcasa se romperá y puedes continuar con el siguiente paso.
