Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 4
Join the lead leaving the resistor to the stripped end of the wire by twisting the two together. The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible. Solder the wire to the resistor.
  • Join the lead leaving the resistor to the stripped end of the wire by twisting the two together.
  • The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible.
  • Solder the wire to the resistor.
  • It is essential that enough solder flows through the wire to create a permanent bond between the two pieces.
Une el cable dejando la resistencia al extremo pelado del cable al unir los dos.
El cable que estamos utilizando es bastante grueso, por lo que insertamos el cable de la resistencia en el centro de la parte del conductor del cable y lo retorcimos lo más apretado posible.
Suelda el cable a la resistencia.
Es esencial que fluya suficiente soldadura a través del cable para crear una unión permanente entre las dos piezas.
