Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 7
Apply a few drops of isopropyl alcohol (90% or greater) under the battery and let it flow around the adhesive to help weaken it. High concentration isopropyl alcohol acts as a solvent and dries without leaving any residue, so it will not hurt your iPhone. Carefully wedge a plastic card under the battery on the side nearest the logic board.
Battery removal with latent adhesive
  • Apply a few drops of isopropyl alcohol (90% or greater) under the battery and let it flow around the adhesive to help weaken it. High concentration isopropyl alcohol acts as a solvent and dries without leaving any residue, so it will not hurt your iPhone.
  • Carefully wedge a plastic card under the battery on the side nearest the logic board.
  • Do not pry against the logic board or you may damage the phone.
  • Avoid prying near the top edge of the battery, or you may damage the upper component ribbon cable.
  • Slide the card from the top of the battery to the bottom, pushing toward the edge of the case.
  • If necessary, repeat the same procedure with the case side of the battery.
Insertar traducción aquí
