Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 8
If the battery is still stuck to the case, follow our iOpener heating instructions or use a hair dryer to heat the adhesive securing your battery to the rear case.
  • If the battery is still stuck to the case, follow our iOpener heating instructions or use a hair dryer to heat the adhesive securing your battery to the rear case.
  • Lay the iOpener flat on the backside of the iPhone to the right of the camera. Smooth it out so that there is good contact between the back of the iPhone and the iOpener.
  • Let the bag sit on the iPhone for approximately 90 seconds before attempting to remove the battery.
  • If using a hair dryer or heat gun, heat the back of the iPhone until it's slightly too hot to touch.
  • Do not apply heat directly to the battery.
  • Overheating the iPhone may ignite the battery.
Sigue nuestras instrucciones de calentado con el iOpener o usa un secador para calentar el adhesivo que sujeta la batería a la carcasa posterior.
Reposa el iOpener plano en la parte trasera del iPhone a la derecha de la cámara. Alísalo para que haya un buen contacto entre la parte trasera del iPhone y el iOpener.
Deja que la bolsa se asiente en el iPhone durante aproximadamente 90 segundos antes de intentar quitar la batería.
Si usaso un secador o una pistola de aire caliente, calienta la parte trasera del iPhone hasta que esté ligeramente demasiado caliente para tocarlo.
No apliques calor directamente a la batería.
[title] Battery removal with latent adhesive
* black] FollowIf the battery is still stuck to the case, follow our [guide|11677|iOpener heating instructions] or use a hair dryer to heat the adhesive securing your battery to the rear case.
[* black] Lay the iOpener flat on the backside of the iPhone to the right of the camera. Smooth it out so that there is good contact between the back of the iPhone and the iOpener.
[* black] Let the bag sit on the iPhone for approximately 90 seconds before attempting to remove the battery.
[* black] If using a hair dryer or heat gun, heat the back of the iPhone until it's slightly too hot to touch.
[* icon_caution] Do not apply heat directly to the battery.
[* icon_caution] Overheating the iPhone may ignite the battery.
