Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 17
Remove the single 6.3 mm Phillips screw securing the upper half of the battery compartment to the Newton. While lightly lifting the upper half of the battery compartment, use the edge of a plastic opening tool to release the five clips along its outer edge. Lift the upper half of the battery compartment and gently lay it on the logic board.
  • Remove the single 6.3 mm Phillips screw securing the upper half of the battery compartment to the Newton.
  • While lightly lifting the upper half of the battery compartment, use the edge of a plastic opening tool to release the five clips along its outer edge.
  • Lift the upper half of the battery compartment and gently lay it on the logic board.
Insertar traducción aquí
