Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 4
Under the hood, locate the connection for the driver's side front hard line on the master cylinder, just below the brake fluid reservoir. The line is the rear line on the driver's side of the master cylinder. Use an 11mm line wrench or open end wrench to loosen the nut on the hard line at the master cylinder.
  • Under the hood, locate the connection for the driver's side front hard line on the master cylinder, just below the brake fluid reservoir. The line is the rear line on the driver's side of the master cylinder.
  • Use an 11mm line wrench or open end wrench to loosen the nut on the hard line at the master cylinder.
Insertar traducción aquí
