Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Before you can begin you'll need to remove the front driver's wheel for easier access to the parts to be removed. Next you'll want to drain the brake fluid from the front driver's side caliper.
  • Before you can begin you'll need to remove the front driver's wheel for easier access to the parts to be removed.
  • Next you'll want to drain the brake fluid from the front driver's side caliper.
  • Loosen the bleed screw on the caliper and allow the fluid to drain in to a pan.
Insertar traducción aquí
