Saltar al contenido principal
Inglés
Español
Paso 2
This is the short coolant hose to be replaced. You can see it leaking in this picture. This is a typical failure. During the thermostat housing removal process you'll have already loosened the upper hose clamp on the short hose. Now loosen the lower clamp.
  • This is the short coolant hose to be replaced. You can see it leaking in this picture. This is a typical failure.
  • During the thermostat housing removal process you'll have already loosened the upper hose clamp on the short hose. Now loosen the lower clamp.
  • With the lower clamp removed you'll be able to pull the short hose off the water pump inlet.
  • Use a pair of pliers for grip if you need to, but it should pull off by hand.
Insertar traducción aquí
