Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Remove the following five screws:
  • Remove the following five screws:
  • One 3 mm Phillips near the screen latch (mind the big magnet on the screen latch).
  • Two 3.5 mm Phillips attaching the EMI fingers to the metal framework.
  • One 10 mm Phillips near the optical drive.
  • One 14 mm long 4 mm standoff in the upper left corner. You can remove this standoff either with a 4 mm nut driver or needlenose pliers.
  • Lift the EMI fingers above the battery connector away from the metal framework.
Insertar traducción aquí
