Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Use your fingernails to carefully pull the ZIF cable lock away from its socket. Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop. Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
  • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
  • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
  • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
Insertar traducción aquí
